Activity Forums Apple Final Cut Pro Legacy A video setting mismatch that I can not locate
  • A video setting mismatch that I can not locate
    Posted by Steven Topham on May 3, 2012 at 5:35 am
    I recorded to DV tape on HDV 30 fps 1080p.
    I set my FCP audio/video settings to:
    -sequence preset: prores 422 (HQ) 1440×1080 30p 48 khz
    + actual footage is at 29.97
    -capture preset: HDV
    -device control: HDV firewire
    Sequence settings were set to:
    -1440×1080(16:9)
    -pixel aspect 1440×1080
    -29.97 fps
    When placing footage in the timeline, it requires it to be rendered. And exported footage looks blurry and bad.
    I had recently change my settings for a standard def project and now I don’t understand why I can’t get them back to the quality I expect. Anybody know where I’m going wrong
    Steven Topham replied 14 years, 4 months ago 2 Members · 2 Replies
  • Edward Brosens
    May 3, 2012 at 7:35 am
    What happens when you click ‘yes’ if FCP asks you to match the sequence settings with the footage?
  • Steven Topham
    May 3, 2012 at 8:39 am
    Good point.
    It changes the compressor from Pro res 422 (HQ) 1080p to HDV 1080p 30.
    And the final result is the brilliant quality I was looking for.
    I don’t necessarily understand why the pro res compression destroyed my image quality so badly, but glad it was a simple fix.
