Activity Forums VEGAS Pro a very ODD and specific audio problem with an MOV file
  • a very ODD and specific audio problem with an MOV file
    Posted by Jonathan Gunn on October 21, 2012 at 12:26 am
    I have footage from a camcorder that is in MOV format and I am editing it using Sony Vegas Pro 11.
    I have tried many different rendering file types with different audio settings and so far nothing has worked.
    Pre-rendered and edited, raw MOV file only plays audio in Windows Media Player. The video plays in Quicktime but the audio is quiet and distorted. And it doesn’t play at all on Media Player Classic.
    Once rendered, the file works 100% perfectly on my desktop PC when played with Windows Media Player, Quicktime, and Media Player Classic.
    But when I play it on a mobile device, the audio is VERY quiet and distorted. BUT the audio works when the headphones are plugged in. I’ve tried it on both an iPhone 5 and Galaxy S2.
    It’s a very odd problem and I can’t find this issue anywhere else.
    Does anyone have an idea why?
    Information according to mediainfo on the audio is as follows:
    Audio #1
    Format : PCM
    Format settings, Endianness : Little
    Format settings, Sign : Signed
    Codec ID : sowt
    Duration : 57mn 15s
    Source duration : 57mn 15s
    Bit rate mode : Constant
    Bit rate : 768 Kbps
    Channel(s) : 1 channel
    Channel positions : Front: C
    Sampling rate : 48.0 KHz
    Bit depth : 16 bits
    Stream size : 315 MiB (3%)
    Source stream size : 315 MiB (3%)
    Language : English
    Encoded date : UTC 2012-10-14 02:09:05
    Tagged date : UTC 2012-10-14 02:09:05
    Audio #2
    Format : PCM
    Codec ID : sowt
    Duration : 57mn 15s
    Bit rate : 768 Kbps
    Bit depth : 16 bits
    Language : English
    Audio #3
    Format : PCM
    Muxing mode : DV
    Muxing mode, more info : Muxed in Video #1
    Duration : 57mn 17s
    Bit rate : 1 536 Kbps
    Encoded bit rate : 0 bps
    Channel(s) : 2 channels
    Bit depth : 16 bits
    Delay relative to video : -1ms
    Stream size : 629 MiB (5%)
    Encoded stream size : 0.00 Byte (0%)
    Thank you all for reading!
    Jeff Schroeder replied 13 years, 10 months ago 2 Members · 1 Reply
  • Jeff Schroeder
    October 21, 2012 at 2:33 am
    Right-click on the audio and try selecting a different stream. Then normalize it.
    2-Xeon X5680 @ 3.33, EVGA SR-2 Mobo, 48GB DDR3, GTX 580 3072MB, 16TB Attached Storage, Win7, Vegas 11 x64
