Activity Forums DaVinci Resolve A very interesting R3D test – good results
  • A very interesting R3D test – good results
    Posted by Blase Theodore on July 20, 2011 at 3:17 am
    I’ve always been a big fan of going back to the debayer to get the best possible exposure out of an R3d before I start tweaking with primary nodes. Aside from getting my temp and tint right, I’d tweak both the shadow and the ISO to expand the image to a full curve.
    I did this because I assumed being closest to the raw data would get me the best image, and I’d have to stretch it less post-debayer.
    Turns out this isn’t the best approach.
    I took a bunch of shots that came out of the camera pretty flat. (Pre-MX chip, lifted shadows, low highlights.)
    I did 2 tests:
    In test 1, I left them at very low ISO’s (like 200), and didn’t touch shadows in they debayer. And I stretched them waaay out with a primary node.
    In test 2, I pre-tweaked the debayer to get to the same place I had gotten with my primary correction.
    I assumed test 2 would prove better results.
    I set render to full quality premium, 16 bit, and rendered out several shots. Turns out they were basically indentical. In fact on a really dark shot, Test 1 actually turned out much nicer than test 2.
    From this I think the following is possibly true:
    – that 16 bit debayer access means that the debayer probably isn’t a bottleneck to the raw data.
    – setting the debayer to an under-exposed ISO, and then stretching the image, gets a cleaner image.
    Cheers,
    Blase
    Blase Theodore replied 15 years, 1 month ago 4 Members · 5 Replies
  • Vladimir Kucherov
    July 20, 2011 at 3:21 am
    I tried a similar test with near-clipped highlights and results coincide with yours – with 16 bit debayer, fussing with ISO doesn’t seem to matter all that much.
  • Joseph Mastantuono
    July 20, 2011 at 12:09 pm
    Thanks for posting this. I wouldn’t have assumed this was the case. It will make things a bit faster as messing with the red stuff on a per shot basis isn’t fun.
    Question though, Can you describe how it looks better? Less noise? Smoother curve?
    Joseph Mastantuono
    Online Editor – Colorist – Post Consultant
    Brooklyn based finishing at reasonable prices
    917.969.1583
  • Blase Theodore
    July 20, 2011 at 3:33 pm
    Interestingly the non-tweaked shot had a much lower noise profile, and a smoother curve.
    I think the raw sensor on the old RED’s was analogous to a 250 or 320 ISO, and that’s where the curve naturally wants to be.
  • Margus Voll
    July 20, 2011 at 9:25 pm
    So the MX could be left to its 800 something ?
    Margus
    https://iconstudios.eu
  • Blase Theodore
    July 20, 2011 at 10:18 pm
    I think the MX is probably closer to 400 ISO. I’d bump it down to 400 or 500 and stretch it up rather than going to 800.
