Activity › Forums › Adobe After Effects › A very easy fade in
A very easy fade in
Posted by Maria Diaz on October 1, 2010 at 6:27 pmI’m an AE beginner and I’m trying to achieve a very easy effect but don’t know how: an image is revealed by having squares in a grid (or mosaics, or whatever) appear randomly. The squares don’t move around, they simply appear randomly until the entire image is revealed. Any ideas?
Jorge Mike replied 14 years, 5 months ago 4 Members · 3 Replies -
Mike Tomei
October 1, 2010 at 6:53 pmNot sure that I’m picturing it the same as you are, but I’m thinking that you could use some masking.
This talks about keying, but also masking:
https://www.videocopilot.net/basic/tutorials/04.Keying/Intel i7-930 2.8GHz
12 GB RAM
1 GB VRAM
Adobe Production Premium CS5
https://www.miketomei.com -
Darby Edelen
October 1, 2010 at 7:11 pmI would recommend creating a solid layer in a new composition and adding the Noise & Grain > Fractal Noise effect to it. Change the settings so that you have a series of blocks:
Fractal Type – Basic (some others may work)
Noise Type – Block
Complexity – 1.0Then place this composition inside the composition with your image (where the transition will occur). Add a Transition > Gradient Wipe to the image. For the Gradient Layer choose the blocky pre-composition you just placed here, for Gradient Placement you’ll probably find that ‘Stretch Gradient to Fit’ or ‘Center Gradient’ will work.
Now you can animate the Transition Completion from 100% (the image is invisible) down to 0% (the image is fully visible). You can set the Transition Softness to some percentage if you want each square to fade in, a higher percentage means a longer fade.
Gradient Wipe is an awesome transition you can use to control the reveal of an image using a grayscale map. I’d recommend playing with the fractal noise composition to see what else you can do!
Let me know if I can clarify any steps here.
Darby Edelen
Jorge Mike
March 28, 2012 at 3:43 pmThank you, worked perfectly.
Now, another question. How can I add a colored grid, so the blocks fade-in just inside each block of the grid.
