Activity Forums VEGAS Pro A very basic question…
  • A very basic question…
    Posted by Charles Martin on June 17, 2011 at 9:41 am
    Apologies for this—-its a very basic question…I’ve just spent 20 minutes trying to find a solution and figured this would be a lot easier.
    How do you cancel an inpoint or an outpoint in the trimmer window?
    pressing ‘i’ selects the IN and pressing ‘o’ selects the out…. how do you cancel either one?
    unless i’m missing something its not included in the Vegas pro manual anywhere—-and if it is its not very clearly marked.
    John Rofrano replied 15 years, 3 months ago 2 Members · 1 Reply
  • John Rofrano
    June 17, 2011 at 12:01 pm
    [charles martin] “How do you cancel an inpoint or an outpoint in the trimmer window?”
    I’m not sure what you mean by “cancel”. There is always an In and Out point indicator. They must be pointing to somewhere. They are just pointing to the same place when you open the trimmer. If you want to collapse them again, press “IO” which will set them both to the same place.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
