Activity › Forums › Maxon Cinema 4D › A Twist in the road , how can i achieve it?
  • A Twist in the road , how can i achieve it?
    Posted by Gnwanya on December 12, 2006 at 1:17 pm
    Hi Guys
    After following tutorials religiously, have managed to create a simple road like shape using the sweep nurbs and a spline. But i want my road to twist a little at chicanes, can anyone help me with this next step. I have tried dropping in a bend boolean, but am not achieving anything thing at the moment.
    Your advice is much appreciated!
    Gus
    Mylenium replied 19 years, 9 months ago 3 Members · 5 Replies
  • Mylenium
    December 12, 2006 at 3:13 pm
    If you mean banking, then you can control it from the rotation spline graph in the “Details” section of your Sweep NURBS.
    Mylenium
    [Pour Myl
  • Adam Trachtenberg
    December 12, 2006 at 3:22 pm
    You can also use a rail spline to control banking. Or you can use deformers by putting the sweepNURBS under a null together with whatever deformers you want to use.
  • Gnwanya
    December 12, 2006 at 4:37 pm
    Thanks Mylenium, Adam
    Im going to look into both approaches.! I appreciate the response.
    Cheers
    Gus
  • Gnwanya
    December 12, 2006 at 4:49 pm
    Hi Mylenium
    Is there a way i can add more than one bank ata chicane on my road?
    cheers
    Gus
  • Mylenium
    December 12, 2006 at 4:58 pm
    Not sure what you mean. If you need more control, use loft NURBS instead of sweeps. You can then rotate each shape separately and control the inbetween segments more selectively.
    Mylenium
    [Pour Myl
