Activity Forums Adobe After Effects A true glossy photo look
  • A true glossy photo look
    Posted by Marc on August 8, 2005 at 6:54 pm
    I’m looking for a way to create a glossy look to a scanned or Digi photo in 3D space…you know the way an actual photo shimmers when moved around, lighting, texture etc…I’ve tried alot of different techniques…just can’t seem to get it to look natural. Is there an quick way to make colors and lighting react with the camera in 3D. Parenting CC light sweep to camera? Help!!!
    Michael Szalapski replied 21 years, 1 month ago 4 Members · 6 Replies
  • Jonathan Miller
    August 8, 2005 at 7:54 pm
    Marc, if you’ve played with the material settings for your 3D layer, and it still isn’t looking right
    it’s probably not what you have that looks wrong. It’s most likely what’s missing that’s wrong.
    You’re not going to have any kind of refelction of your photo’s environment.
    Look at a photo, and if it’s glossy you’ll see yourself staring back in reflection.
    If you need to stay within AE to do this project, and you have access to Zaxwerks Invigorator, you could probably get things to look the way you want. You can use the photo as a texture map within Invig., and then use another still of the photo’s surrounding (or better yet, video) as a refelction map.
    If you don’t already have the plugin, you can download a demo to see if it would be worth the investment for you (if you can afford it, it will be worth it.)
    Good luck!
    Jon
    TreeLine Productions
    Fort Collins, CO USA
  • Marc
    August 9, 2005 at 3:05 am
    Thanks for your response. I do have Zaks Inv, and the reflective properties in it work great once I apply the photo to my a vector rectangle. Do you know of any other way I can create this same effect without going into a 3D app like Zaks Inv…It’s so darn RAM gobbling! The photo itself that is to be reflective does not need to be 3D, just 2 1/2D if you know what I mean.
  • Jonathan Miller
    August 9, 2005 at 2:16 pm
    Yeah, I know what you mean. I can’t think of any way as straight forward as Zax to make it work. Have you tried setting your Invig. layer to draft mode while you create the animation? It should render very quickly in the Comp window. Then once you’ve got your motion the way you want, set the layer(s) back to full quality for your final render.
    Good luck!
    Jon
  • Serge Hamad
    August 9, 2005 at 4:15 pm
    I would also work with Invigorator for this as it gives the best results. Without Invigorator you may want to try the CC-Light Sweep effect.
    Here is a way of using it:
    https://www.nyc-visual.com/light_sweep.sit
    looks like this:
    https://www.nyc-visual.com/light_sweep.mov
    The example was done quickly but it may give you an idea. Notice the transfer modes of the light sweep layers, their parenting and the two expressions that tie the light sweep Direction parameter to the X & Y Rotation axis of your picture.
    I hope this may help.
    Salut.
    Serge
  • Marc
    August 10, 2005 at 6:25 pm
    Is there a way to use video in Zaks inv classic…other than targa and jpg as a reflective source?
  • Michael Szalapski
    August 19, 2005 at 8:31 am
    Yes, have your video layer in your composition. (It can have the eyeball turned off.)
    In the effects pallete set it as Layer map 1 (or two or three…)
    In the Invig Options set Layer Map 1 (or whichever it is) as your reflective source.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great)
