Activity › Forums › Apple Final Cut Pro › A transition effect to a title!
Posted by Floris Kotze on June 23, 2011 at 2:56 pmHow do I add a transition effect to a title?!
Justin Hall replied 9 years ago 5 Members · 9 Replies -
Brad Jordan
June 23, 2011 at 3:23 pmAs for “Fade In/Fade Out” transition, there is an “In Opacity” and “Out Opacity” in the Inspector for the titles that are keyframe-able. Parameters for Scale, Motion, etc also there.
Looks like you can’t add a “Cross Dissolve” or other transition as you would with a regular clip.
Jonathan White
June 23, 2011 at 3:25 pmI’m not in front of the computer now but I think you have to turn it into a storyline ( select then apple-G), then you should be apple to apply transitions…
JohnnySeanchas Productions, Galway, Ireland
Brad Jordan
June 23, 2011 at 3:31 pmIf you make the text object a compound clip, than it acts as a typical video clip and you can add transitions to each end. But it looks like you can do a lot in the text object’s inspector tab.
Floris Kotze
June 23, 2011 at 4:53 pmThanks guys. I’m using the blur transition for this. If you create a compound clip, it stuffs up the alpha of the title, ie it cuts to black as you blur it in or out. I’ve tried alotta work arounds, nothing! Absurd! Am I suppose to ‘fade’ all my titles in or out!?
Nevin Styre
June 23, 2011 at 5:35 pmI’ve figured a workaround to get transitions behaving right on titles. I have a feeling this technique is going to come in handy for a lot of FCPX issues.
1. You need to make an alpha slug, I just made an empty 1920×1080 document in photoshop, set the background to transparent and saved it as a PNG file called ALPHA_SLUG.png.
2.Create your title overtop of your footage, place the alpha slug in front of the title (1 second length for slug is good enough). Select both the slug & the title and create a compound clip, now open the compound clip and you can add any transition between the slug and the title, back to your timeline and voila.
Nevin Styre
June 23, 2011 at 5:38 pmWell it was working, but now it seems to be doing weird things with the alpha channel, I will do some more testing.
Floris Kotze
June 23, 2011 at 5:56 pmThanx allot for trying to help. It’s such a pain! All this resources tied up to do something that should take 2 clicks max!
Nevin Styre
June 23, 2011 at 6:36 pmIt’s hard because it doesn’t seem like there’s any rhyme or reason to it, it just decides sometimes that it will transition properly to the alpha, but 50% of the time it decides during the transition that the alpha is a black solid.
However, I have found if you make a working compound clip with the alpha, transition & title, you can copy and edit it without it messing up the alpha. So once you build a working compound clip copy it and use that. You might need to make a few to eventually get a working one, try it in a new project if it isn’t working in current(you can copy across projects).
Building another from scratch isn’t guaranteed to work, copying a working one seems to be more consistent. Some transitions still won’t work without messing up the alpha(moreso the cheesy or complex ones, blurs & dissolves seem fine). Some transitions will make the text appear on a black solid background in the compound clip after the transition, however back on the main timeline the black renders as transparent so it still “works”.for some reason I’m reminded of this 90’s anti drug commercial “this is your brain on drugs”.
FCPX please come down off the acid and work with us in reality.
https://www.youtube.com/watch?v=PCIJNiJisloSome contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Justin Hall
September 12, 2017 at 4:32 amI’m aware this thread is very old, but I’ve been wondering about this same issue for ages and came across this incredibly simple, but genius solution in a Youtube video from Ben Halsall. The basics of the method are as follows:
1. Extend your text layer a little past the point where you’d like the transition to appear
2. Blade the text layer at the point where you want the transition to appear
3. Add the transition to the new cut you’ve just created in that text layer
4. Lower the opacity of the first section of the bladed text layer (ie the part before the transition) to “0”
Obviously if you want the transition at the end of the clip the steps are the same, but then you’d be lowering the opacity to zero at the extra section after the transition
Here’s the video if I wasn’t clear enough:
https://www.youtube.com/watch?v=nuKnrRohlN8
