Activity Forums Maxon Cinema 4D A tiny cone object
  • A tiny cone object
    Posted by Miem Chan on March 14, 2006 at 10:49 am
    I’m trying to create a small cone with the following dimensions;
    Top radius : 2mm (or zero)
    Bottom radius : 15mm
    Height : 7 cm
    BUT, resultant object does not have sharp tip.
    Probably this is due to some precision issue. How can it be fixed?
    Also after pressing Alt+H (Frame Scene Without Camera/Light) in perspective window, I can not see the object but it renders if Ctrl+R pressed. How this Alt+H can be fixed?
    Miem
    Björn Marl replied 20 years, 6 months ago 2 Members · 1 Reply
  • Björn Marl
    March 14, 2006 at 3:44 pm
    Sorry, i can’t reproduce that. If i create a cone with 7 units height and 15 units bottom radius the tip is sharp.
    Maybe your camera is heavily distorted? Please try to parallel view and back to perspective to check for this
    Cheers
    Bj
