Activity › Forums › Adobe After Effects › A Time Displacement Problem
  • A Time Displacement Problem
    Posted by Gal Muggia on July 30, 2009 at 9:10 am
    I have a common time displacement problem in After Effects.
    I’m trying to achive a smooth Slit-Scan effect on 720p HD material.
    Since the “Time Resolution” value is limited to “127.0” I recive thick lines instead of smooth motion. Entering a value larger than “127” dose’nt change the result.
    Is there a plugin that can work with HD material?
    If not, What should I do? Is there another program I should use?
    G Muggia
    Gal Muggia replied 17 years, 2 months ago 2 Members · 2 Replies
  • David Bogie
    July 30, 2009 at 4:31 pm
    Displacement and compound effects rely on the quality of the offset map which is a grayscale image or it’s take from the luma value of one channel of a map layer. what does your map layer look like?
    127 is half of 255, the number of shades of gray AE can use in compound effects.
    bogiesan
  • Gal Muggia
    July 31, 2009 at 2:33 pm
    First of all, thanks!
    I’m using a grayscale gradient i created in photoshop with the gradiant tool.
    Should I use a different type of displacement map?
    Is AFX the right program for me?
