Activity › Forums › Boris FX Particle Illusion › A tank Barrel firing, is this possible?
  • Elvis Deane
    February 24, 2006 at 5:39 pm
    Yes, there are a good number of emitters that can be used to do this sort of effect. One of the Super Burst emitters in the August 2003 library is probably a good start, since it has both a flash of light and a burst of smoke. The Smokey Sparkle Burst emitters in December 2003 would also be a good start if you lower the Emission Range to 0, which gives the effect of the projectile blasting out with flash and smoke, rather than just the flash.
    Elvis Deane!
    The particleIllusion FAQ
    particleIllusion Resources and tutorial CD
    Astounding Adventures
  • Jack Hilkewich
    February 24, 2006 at 8:44 pm
    Hey Thanks Elvis, If this looks good when I’m done I think I will be able to convince my company to buy this software. The demo is awsome!!
