Activity Forums Adobe Premiere Pro a sync vob.avi
  • a sync vob.avi
    Posted by Joep88 on February 7, 2006 at 3:26 pm
    Hello,
    I am editing a AVI file which originally is a DVD vob file.
    I renamed it and that works fine. There is no problem in the first
    10 minutes but after that the audio becomes out of sync.
    Any ideas ? I also tried a ripped version of it, but gives the same problem.
    http://www.multimediasolutions.nl
    ASUS P4C800 de luxe
    Matrox Parhelia 225
    BMD Decklink Pro
    2 gig internal memory
    2x 120 gig HD
    Multible Firewire Disks
    Adobe Premiere Pro
    Combustion 3.0
    Photoshop
    Adobe Audition
    Cubase SE
    S
    Aanarav Sareen replied 20 years, 7 months ago 2 Members · 4 Replies
  • Aanarav Sareen
    February 7, 2006 at 4:52 pm
    How did you convert your file to an AVI? What application? What settings? How bad is the sync? A couple of frames or a couple of minutes?
  • Joep88
    February 8, 2006 at 9:24 am
    Yes, sorry i was a bit lazy in giving information 🙂
    What i first did was just copy the file (500mb) and renamed it to test.avi (as recommended
    by adobe) that gave a lot of sync problems. The first minute is fine, after that it shifts
    really 30, 40 and more seconds.
    What i know now is that it is almost impossible to edit compressed dvd material and that it has to be converted. So used Video2 from Magix (have to say it rocks) it can read VOB files (!). And i exported these as AVI DV files. No problem anymore. The only problem is now rendering. If i want to render the file in Premiere Pro it give an I/O error. Only with this kind of files.
    Joep
    ASUS P4C800 de luxe
    Matrox Parhelia 225
    BMD Decklink Pro
    2x 120 gig HD
    Adobe Premiere Pro
    Combustion 3.0
    Photoshop
    Adobe Audition
    Cubase SE
    S
  • Aanarav Sareen
    February 10, 2006 at 1:52 am
    [joep] “What i first did was just copy the file (500mb) and renamed it to test.avi”
    This is where your problem lies. You should have named it test.mpg and not .avi.
  • Aanarav Sareen
    February 10, 2006 at 2:04 am
