Activity Forums Adobe After Effects A simple problem for you
  • A simple problem for you
    Posted by Ivan Jovic on May 11, 2008 at 5:52 pm
    OK Guys…this is my problem I there a way that I can import black and white image (not gray)!, and use it as mask layer…….and can I do the same with black and white (again no gray color just black and white)!
    Simon Bonner replied 18 years, 3 months ago 2 Members · 1 Reply
  • Simon Bonner
    May 11, 2008 at 10:42 pm
    Are these two different problems? If so, explain them further so readers can understand more clearly.
    If you’re asking, can you use a black and white monochrome image as a mask / matte? then yes, you can.
    Place the b&w image above your footage in the layer stack and then set the track matte of your footage to luma matte or luma matte inverted, depending whether you want to see through the white or the black.
    Simon Bonner
    youtube.com/simonsaysFX
