Activity Forums Adobe After Effects A simple key frame question
  • A simple key frame question
    Posted by Malcolm Desoto on August 20, 2007 at 5:36 pm
    How do you move a layer so that the key frames come with it? As of now, I drag the clip and the key frames stay behind. I used to know how to do this but it seems to have slipped my mind. Not really sure what to look this up as in the manual.
    I’m sure someone here kwows.
    Thanks.
    Malcolm Desoto replied 19 years, 1 month ago 2 Members · 2 Replies
  • David Bogie
    August 20, 2007 at 7:14 pm
    Drag the layer where?
    If you move it in the layer section of the timeline, all attached information moves with it.
    If you are trying to drag it in the timeline, you must select all of the keyframes in order to change their time values.
    bogiesan
  • Malcolm Desoto
    August 20, 2007 at 7:45 pm
    Sorry. I meant, move it in the timeline. Weird, there’s no way to nudge a layer without having to select all the key frames?
