Activity › Forums › Adobe After Effects › A simple 3D floor
  • A simple 3D floor
    Posted by Rob Wolf on October 6, 2005 at 6:32 am
    Something that seems like it would be really simple is proving to be a real pain for a newbie like me.
    I’d like to create a simple white foor that sort of vanishes into a black horizon.
    I’ve started with a comp with a black background, a white 3D solid (scaled up by 1000 percent), and have been playing around with various cameras and lighting settings. I just can’t seem to get it looking quite right. The floor is always too greyish, and the horizon is either too sharp or non-existent.
    I imagine this is a starting point for many After Effects projects. Can anyone suggest a good set of initial settings to get me started?
    Rob
    Graham Quince replied 20 years, 12 months ago 2 Members · 1 Reply
  • Graham Quince
    October 6, 2005 at 8:05 am
    It’s probably not the best approach, but with stuff like this i usually cheat. You could try adding a mask to the ‘horizon end’ of your layer, and feather that mask. Also, if it’s a set look you’re going for, you could create a horizon in photoshop and parent it to the far end of your layer
    Graham
    http://www.qcit.com
