Activity Forums Apple Final Cut Pro Legacy A silly question using EDLs
  • A silly question using EDLs
    Posted by Jay Cornelius on June 17, 2005 at 7:22 am
    I’m bringing in aan EDL from another app… using setting clips to unique names.
    In FCP the sequence opens up and a number of source clips…
    This nwould be great if I wanted to re-capture the clips.
    But, these clips are all from one tape, of which I captured the whole tape to Online.
    I want to relink the seperate clips to one source clip, using the timecode as sync reference.
    Any ideas?
    I reverted to manually laying the cuts, using the timecode as ref.
    Walter Biscardi replied 21 years, 3 months ago 2 Members · 1 Reply
  • Walter Biscardi
    June 17, 2005 at 10:39 am
    Not sure if what you want to do will work. Generally it’s much better to recapture the clips to the EDL. Basically each of those clips are a Master Clip and FCP will more than likely have a problem trying to reconnect all the Master Clips to your single captured clip.
    I do this workflow now with a show that’s cut on an AVID for the SD version of the show, then they shoot me an OMF which I convert via the Automatic Duck plug-in and conform the show to HD on my Kona 2 system. Works extremely well.
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
