Activity Forums Adobe After Effects a “shooting-a-tv-screen” effect
  • a “shooting-a-tv-screen” effect
    Posted by Emmanuel Gobert on November 14, 2009 at 10:00 am
    hi everyone,
    i am trying to reproduce the style of picture you have when you shoot a tv screen with a camera
    here what i have now: https://vimeo.com/7601747
    i will had some “bad tv” effects and things like that, but i am ot very satisfied by the result
    in fact i’d like to have something like that : https://www.wyldstallyons.com/work/blocparty/
    (i am not talking about “bad tv style” but more about the “texture” of the picture)
    any idea on how to reach this result ?
    thank you !
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    David Johnson replied 16 years, 9 months ago 3 Members · 2 Replies
  • Graham Quince
    November 14, 2009 at 2:52 pm
    I’ve tried various times to recreate this effect, using things like the venetian blinds transition, the CC Balls filter and even creating an image with a repeating black grid-like pattern. The best results I got came when I set my camcorder to Ski/winter mode and filmed the footage through my CRT TV.
    Graham
    http://www.YouTube.com/ShiveringCactus – Free FX for amateur films
  • David Johnson
    November 14, 2009 at 4:39 pm
    Graham’s approach is definitely the most realistic, but in case your cam doesn’t have that kind of setting, you could also make a file in Photoshop with alternating lines of dark and lighter grey to simulate TV fields. Add some noise or grain. And use a bullnose mask so the edges aren’t a sharp rectangle. Then, lay it over your footage in AE using a blending mode of your choice … I forget which works best, but maybe screen or add with slightly lowered opacity so that it also simulates the slight glow of a TV screen. While there are better methods (some using third-party plugins), this method renders pretty quickly so it just depends on your specific needs/preferences.
