Activity › Forums › Adobe Premiere Pro › ‘a serious error has occured that has caused premiere to shut down’
  • ‘a serious error has occured that has caused premiere to shut down’
    Posted by Ian Davies on August 18, 2009 at 8:58 am
    Hi
    I have a one minute sequence with video footage, sound and titles. When trying to export through media encoder, I’m getting the message ‘a serious error has occured that has caused premiere to shut down.’ Baffled…
    Ian
    Ian Davies replied 17 years, 1 month ago 3 Members · 4 Replies
  • Vince Becquiot
    August 18, 2009 at 4:36 pm
    Format, computer specs, export settings?
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
  • Ian Davies
    August 19, 2009 at 8:27 pm
    Specs are single 1.8ghz processor, 2 gig ram (4G page file), 150 gig hard disk space with 50 gig free.
    I know this may be a bit short but I can usually export to AVI when using standard frame dimensions. However a client has asked for video dimensions of 1000×520 and this is when I encounter the error and shut down.
    I dont get far enough to set the export settings.
    Any help appreciated.
    Ian
  • Jon Barrie
    August 19, 2009 at 11:30 pm
    Have you created a custom timeline with the dimensions you need to edit in?
    New Sequence, General Tab, Set to Desktop and customize the fps, frame dimensions, PAR, Audio etc. Name the seq and OK.
    CS3 you need to set this at New Project stage, CS4 can do this at any point in the Project’s life.
    That might help on export.
    – JB
    Jon Barrie
    aJBprods
    http://www.jonbarrie.net
  • Ian Davies
    August 20, 2009 at 8:27 am
    Hi Jon
    I’m using CS4 but did set the sequence to the correct dimensions. The client asked me to set the sequence preset to mobile devices (Ipod, QUGA, Sub-QGIF) which gave me the dimensions that’ll fit the required framework.
    I originally completed the project (before they told me of their dimension requirements) using different dimensions which exported without error?
    Ian
