Activity Forums Adobe After Effects a script to offset selected layers by 1,2 frames
  • a script to offset selected layers by 1,2 frames
    Posted by Jason W. miltt on June 10, 2009 at 6:49 pm
    Hi:
    I have been looking for a script that does this but coudnt find anything.
    You select 10 layers.
    Launch the script.
    A window popups. You enter 1.
    Layers are offseted from bottom to top by 1 frames one after the other.
    like this:
    ___—–
    __—–
    _—–
    Jason W. miltt replied 17 years, 3 months ago 2 Members · 2 Replies
  • Andy George
    June 10, 2009 at 6:52 pm
    Hi Jason,
    Select the layers you wish to sequence. Go to Animation-Keyframe assistant-Sequence Layers.
    Make sure the “Overlap” button is ticked. enter your overlap duration.
    Here is a link to a script that will do the same thing only starting at your current composition time. #21 “SequenceLayers”
    https://www.nabscripts.com/downloads_en.html
    Andy
  • Jason W. miltt
    June 10, 2009 at 7:21 pm
    hey thanks. I like the script better since the keyframe assistant only was offsetting to comp size for some reason.
