Activity › Forums › Adobe After Effects › A Script to access Sourcetext
  • A Script to access Sourcetext
    Posted by Erin Shelby on September 27, 2005 at 12:27 am
    Okay, I was doing OK w/ expressions but for some reason scripts have me a bit messed up…
    I’m trying to write a script that accesses:
    -a specific comp,
    -then a specific text layers character length
    -then put this information somewhere else (eg: display this on another text layer, set as x-position of a solid…)
    So if a string had 100 characters, running the script would tell you it had 100 characters in another textlayer, or it could set the position of a solid layer…I know how to do it w/ expressions, but the problem is that the user of the AE file will want to ‘tweak’ the information after – so I don’t want the information continually updated – they can just run the script once and have get a ‘hint’ of the information and tweak afterwards if they want…
    This question is more about basic scripting, accessing specific values (all the example scripts can do fancy things like find a certain string in *all* the text layers of a file, but how do I make it just access a specific comp, specific layer)?
    Sorry if I’m confusing, it’s just I thought the transition to scripts would be easier….
    -echo
    Erin Shelby replied 21 years ago 2 Members · 3 Replies
  • Erin Shelby
    September 27, 2005 at 12:36 am
    actually, let me reduce my thought more…
    okay, lets say I have a comp called Bongle and a layer called Dongle…how would I access the sourcetext property of that layer in a project?
  • Dan Ebberts
    September 27, 2005 at 12:46 am
    I haven’t tested this stuff, so there may be errors, but basically it’s like this. Finding a specific comp in the project window is kind of clunky, but you can do it like this:
    var compName = “xxxx”; //comp name goes here
    var myProject = app.project;
    var n = myProject.numItems;
    var foundIt = false;
    var i;
    for (i=1; i<=n; i++){ if (myProject.item(i).name == compName){ var myComp = myProject.item(i); break; } } Finding a layer in a comp is pretty much the way you do it in expressions: var layerName = "yyyy"; //layer name goes here var myLayer = myComp.layer(layerName); Getting the length of a layer's source text would look like this: var mySourceText = myLayer.text.sourceText; var mySourceTextLen = mySourceText.len; Hope that's helpful. Dan
  • Erin Shelby
    September 27, 2005 at 1:00 am
    ah, I believe I understand…
    very much appreciated.
