Activity › Forums › Apple Final Cut Pro Legacy › A Scanner Darkly effect.
Posted by Alieninnovation on August 5, 2006 at 4:22 pmHow is this effect done?
It looks like a Filter, maybe somebody can give out some tips how to make this effect.
A course only in the Apple tools: FCP, Shake and Motion. No After Effects here.If this has been disgusted before, please post link.
Trevor Anderson replied 15 years ago 7 Members · 6 Replies -
Kevin Monahan
August 5, 2006 at 5:34 pm[Alieninnovation] “If this has been disgusted before, please post link.”
I resemble that remark!
Kevin Monahan
Take My FCP Master’s Workshop!
fcpworld.com
Pres. SF Cutters -
Tony
August 5, 2006 at 5:59 pmNo don’t duplicate or copy this effect instead be original.
Shoot 35mm film and then apply a filter to downgrade it to make it crappy DV like.
Now that’s an effect no one has been using regularly so be the first one to start a trend.
Tony Salgado
Shane Ross
August 5, 2006 at 9:27 pmThat wasn’t a simple filter. That was software specifically designed for this process, and rendered out image frame by frame. It was started on WAKING LIFE.
Shane
Littlefrog Post
http://www.lfhd.net -
13
August 5, 2006 at 10:16 pmThe closest thing I have seen is a tutorial here on the Cow but it dose require After Effects
I dont realy like the result of it though
I have seen good results on still images in photoshop but would require doing it frame by frame
(way to long for me right now) -
Eli Mavros
August 7, 2006 at 2:34 pmThis is not just a filter, or a program. Yes they did use a special program that was created by a guy named Bob Sabiston, but as far as I know it is not available for purchase by the general public. Though they had this program, it wasn’t a matter of just running the footage through it and presto! it’s done. Thise “look” is the work of hundreds of rotoscopers and animators…it is a very tedious process.
Best,
Eli MavrosEli Mavros
Trevor Anderson
July 26, 2011 at 7:11 amLiveToon plugin converts live action footage to cartoon, similar to A Scanner Darkly. Check it out here https://www.dvshade.com
Movie Mavericks – Movie Reviews & More
https://moviemavericks.com
