Activity Forums Adobe After Effects A reverse “Set Proxy” command?
  • A reverse “Set Proxy” command?
    Posted by Matthew Groves on August 13, 2010 at 2:22 am
    In some work, the client has images from istockphoto.com that we’re using, but they’re only the low rez/watermarked version (the proxy, not to confuse it with the AE proxy).
    After I’m done the project, it would be nice if I could simply point to the high rez file and let er rip.
    So, is there a way to designate a file that’s already being used in a project as a proxy for a high rez that you won’t actually have until the project is ready to render?
    I assume most people have a workflow like this:
    Use free proxy of image
    Get client approval
    Purchase hi rez version
    substitute high rez for low
    You can’t just use “replace footage” because it won’t retain the formatting. I realize that if I already had the high rez version that I could create a proxy, but I only get to start with the low rez.
    Any Idears?
    Jason Byfield replied 16 years, 1 month ago 4 Members · 4 Replies
  • Todd Kopriva
    August 13, 2010 at 6:18 am
    You should be able to use the normal proxy features to do what you’re describing. Read this page.
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
  • Matthew Groves
    August 13, 2010 at 1:22 pm
    I understand how to use proxies in the normal way, but this is different.
    Normally, you start with a hi-res footage and you make/set a proxy of a low-res version for faster processing. I get that.
    If you *start* with lo-rez, though, your footage will usually be scaled way up. If you try to trick AE my setting a proxy using the high-rez file, it’s pixelated because it tries to “preserve” the scaling of the original (lo rez in this case) and then reduces it to fit the original dimensions.
  • Matthew Keane
    August 13, 2010 at 5:36 pm
    This may not be the smartest way to do this but, since the stock video previews are often in formats that AE doesn’t really like anyway – flv or h264 – I recompress them using another codec and, at the same time, scale them up to the final HD dimensions – that way the hi-res versions can just be dropped into the project in place of the lo-res versions.
  • Jason Byfield
    August 14, 2010 at 12:15 am
    You don’t even need to transcode. Just drop the proxy footage in a comp, scale up and then precompose so that AE is tricked into thinking it’s scaled at 100% instead of higher. Then you can just replace the nested comps with the high-res footage using Alt + drag and drop. Don’t forget to select the layer you are replacing first though.
