Activity Forums VEGAS Pro A rendering question
  • A rendering question
    Posted by Anthony on January 14, 2006 at 8:48 pm
    Rendering a 100k stream wmv file thats 45 mins long (41mb). I have a 4200 dual core amd, usually it renders in close to real time. This computer is offline and nothing was open but vegas 6. I closed the preview window before starting because I heard it will go faster.This file was the first I ever color corrected, it took 10 hours to render.When I checked system resources both cores were rendering at around 57%. Did it take that long because I color corrected and is there a way to get the cores to work at 100% ?For color correction I was using the tools in vegas not magic bullet.
    Anthony replied 20 years, 7 months ago 2 Members · 4 Replies
  • Gary Kleiner
    January 16, 2006 at 12:16 am
    Color correction CAN add a lot of render time depending on what you’ve applied.
    Did you change the # of rendering threads in preferences?
    Gary Kleiner
    Vegas Training and Tools.com
    Learn Vegas and DVD Architect
    http://www.VegasTrainingAndTools.com
  • Anthony
    January 16, 2006 at 12:39 am
    i have it set to 4 should i set it higher?
  • Gary Kleiner
    January 16, 2006 at 2:15 pm
    [Anthony] “i have it set to 4 should i set it higher?”
    No.
    What do you have your RAM allocation set to? Try setting it to 16 before rendering and see if it goes faster.
    Gary Kleiner
  • Anthony
    January 19, 2006 at 5:56 am
    that was the problem i had the ram set to half the ram on my system 1 gig. I had changed it after I watched a tutorial. it dawned on me i didnt have this problem before. so i put it back to 64 now it rocks again,maybe not having a clue has its merits lol
