Activity › Forums › Adobe After Effects › A really basic problem? re: Blur
  • A really basic problem? re: Blur
    Posted by Tonybazza on July 26, 2007 at 5:17 am
    Hi Guys,
    I am new to after effects. I want to make a video for my 21st, i am making a re-make of the blink 182 film clip whats my age again (seen here https://www.youtube.com/watch?v=rCjbphQH2iE )
    The only thing i am having troubles with is how to blur the groin region?
    How do i blur that area and make the blur stick to the groin area without having to do it frame by frame?
    Is there a way i can select the pixels and that can follow the pixels all the way through?
    What tool would i use for this?
    Also what is this called? Is this called motion blur?
    Thanks guys
    Tonybazza replied 19 years, 2 months ago 2 Members · 4 Replies
  • Michael Duff
    July 26, 2007 at 6:10 am
    you could duplicate the footage, blur the top layer, mask out the area you want, then keyframe the mask to move where you want it… you wouldnt need to do every single frame… but you would need to do quite a few depending on how much movement there is in the shots… I’d recommend this way if you are new to AE.
    instead of duplicating the footage you could use an adjustment layer with the blur effect, then mask out the area you want.
    there is the possibility that you could use motion tracking so that you didn’t have to keyframe it… but that can get a it more confusing…
    ….motion blur when refered to in AE is simply when AE puts a blur onto keyframed objects that move across the screen … like how things look when they move on a real camera.
    If you don’t understand these techniques then check out the help section and search the cow for words like “motion blur” “mask’ “adjustment layer” “motion tracking” “track matte” “mosaic” …. if you’re still stuck let us know
  • Tonybazza
    July 26, 2007 at 6:41 am
    Thanks alot for your help. I will do some research on those words now.
    So theirs isnt a way where i can select pixels and a tool that will allow the blur to stick to those pixels?
  • Michael Duff
    July 26, 2007 at 10:50 pm
    do you mean motion tracking? AE can track the motion of a group of pixels on the screen and then you can attach something to it (like a blur matte) … but it’s not always as easy as just picking a pixel and hitting go …. you need a distinct object to track to and AE then tries to calculate the motion …. give it a go, maybe it’ll work for you…. but chances are it’ll still need lots of tweaking …
  • Tonybazza
    July 27, 2007 at 5:32 am
    ok cool i will try this, what tool do i use to select the pixels? i tried the pen tool but had no luck…
