Activity Forums Boris FX Particle Illusion A question about widescreen.
  • A question about widescreen.
    Posted by Kurt Muller on September 2, 2009 at 9:58 am
    Hi guys,
    I’ve read a lot of the threads on this subject but if you could just put it into moron terms for me, I’d be very grateful.
    I capture, edit, and burn my films to DVD in Premiere Elements 7. I’ve begun to shoot everything in widescreen, since my Canon MVX40i says it shoots real widescreen.
    Okay, so I capture the footage, edit, and then I decide to take some of the shots into PI SE for adding particle effects.
    Clicking on the little gray stage, and then selecting the widescreen scene, I only get a squeezed version of it. When I go ahead and apply a perticle effect, then save it to avi, it comes out unsqueezed okay, but now the particle effect is stretched.
    So, in the simplest possible terms, please explain what I have to do to get that original widescreen footage into the stage at its original widescreen aspect, so that a particle effect will match the aspect?
    Kurt.
    Kurt Muller replied 17 years ago 2 Members · 2 Replies
  • Alan Lorence
    September 2, 2009 at 2:08 pm
    Kurt,
    You need to use the square pixel equivalent resolution in particleIllusion, as particleIllusion only supports square pixels at this time.
    Do a “search” in this forum for “square pixel equivalent” and see if you find the answer.
    Alan.
    http://www.wondertouch.com
  • Kurt Muller
    September 4, 2009 at 12:26 am
    Done, and done.
    Thanks, Alan.
