Activity Forums Adobe After Effects A Question about Expressions
  • A Question about Expressions
    Posted by Sascha Engel on July 30, 2010 at 12:55 pm
    I pick-wipped a position of a lens flar to the Position of a Null Layer (Tracking Data).
    NOw, the Flare is following the shot in the right way, but unfortunately the beginning position of the Flare is wrong. Where and How do I have to ad the offset x and y co-ordinates to reposition the flare?
    Thanx a lot.
    Sascha
    Sascha Engel replied 16 years, 1 month ago 2 Members · 2 Replies
  • Bartek Skorupa
    July 30, 2010 at 1:23 pm
    You could for example add the following to the expression generated by the pick-whip:
    +value
    This means that the original value of the flare position will be added to the pick-whipped value.
    This way you can easily change the original value so that it matches your needs.
    Bartek Skorupa
    Warszawa, Poland
  • Sascha Engel
    July 30, 2010 at 2:16 pm
    Tried it, it’s a rather difficult, cause it is adding to existing value – it involvves quiet a bit trial and error. I remember, there’s just some information you can ad to the x and y axis to shift it a certain amount of pixels.
    Sascha
