Activity › Forums › Adobe After Effects › A question about building a render farm
  • A question about building a render farm
    Posted by Mike Schmitt on September 20, 2005 at 1:33 pm
    Hi there:
    Last year I purchased a Dell Precision 650 with dual 3.2 Xeons, 4 Gigs of RAM and an Nvidia QUadroFX 3000 video card. Everything is SCSI in my system and I’ve got a Medea Video RAID and G-tech Firewire drive… and an assortment of lesser firewire drives I keep my sound effects and stuff on.
    This year I want to get into hi def or just HDV and I’m learning that for my needs I may need to purchase a turnkey system with something like the Matrox Axio or a Kona card.
    The system I’m looking at uses SATA drives and AMD 64 bit processors. I have two questions:
    1: Can I create a render farm using this new 64 bit workstation and my current 32 bit workstation?
    2: Will it work if the new computer is SATA and my current computer is SCSI?
    Thanks for any suggestions!
    MIKE
    Barend Onneweer replied 21 years ago 2 Members · 3 Replies
  • Barend Onneweer
    September 20, 2005 at 1:52 pm
    Although AE isn’t 64-bit yet it will run fine on a 64-bit CPU and even on 64-bit Windows.
    If you want to do network rendering you can mix and match different CPU’s without a problem, although it’s better to stick to one OS.
    There’s also no problem if one system uses SCSI and the other uses SATA.
    Bar3nd
    Forum COWmunity leader for:
    ADOBE AFTER EFFECTS
    MAGIC BULLET SUITE
    INDIE FILM & DOCUMENTARY
  • Mike Schmitt
    September 20, 2005 at 6:16 pm
    When you say the sam OS, you you mean using Windows 64 on one and XP Pro on the other won’t work?
  • Barend Onneweer
    September 20, 2005 at 6:31 pm
    Well, I haven’t tried networking XP64 and XP Pro yet, but I think that should work well. It’s the networking Macs and PC’s that can be a bit more complicated for network rendering.
    Bar3nd
    ADOBE AFTER EFFECTS
    MAGIC BULLET SUITE
