Activity Forums VEGAS Pro a problem related to sony vegas pro 10 and 7D canon mov files
  • a problem related to sony vegas pro 10 and 7D canon mov files
    Posted by Nizar Abu zayyad on June 20, 2012 at 12:45 pm
    im editing short drama episodes on vegas pro 10, i import mov full HD files from canon 7D to the timeline with these settings
    Template 1080-50i (1920×1080) 25fps
    Field order: none progressive
    Frame rate: 25 PAL
    Pixel formate: 8bit
    Full resolution: Best
    Motion Blur type: Gaussian
    Deinterlace method: Blend Fields
    and when i render the project i face a problem at the end of the video where i lose sync and the video gets in slow motion then fast speed for a couple of seconds! any clue how to fix this? is it related to the project settings? i tried to disable resample for all the clips and nth happened also
    Al Bergstein replied 14 years, 3 months ago 2 Members · 1 Reply
  • Al Bergstein
    June 21, 2012 at 4:04 pm
    Why are you choosing interlaced? The camera doesn’t shoot interlaced. Try changing the timeline to non interlaced and then rendering it out.
    Al
