Activity › Forums › AJA Video Systems › a possible answer to PTT problems
  • a possible answer to PTT problems
    Posted by Bob Cole on January 26, 2008 at 9:39 pm
    This may be redundant, but I’d like to share for once an ANSWER (possibly) to a recurrent LHe/FCP problem: when printing to tape, the Kona card occasionally gets confused and outputs its characteristic “I don’t UNDERSTAND” vertical-only color bars.
    And nothing else.
    No FCP sequence comes forth, no FCP countdown — all you get are these vertical color bars.
    I found a possible answer, after trying all of the traditional fixes (restart, trash prefs, burn incense…) in vain.
    I had two projects open in FCP when I was having the problem. As soon as I closed the irrelevant project, the problem was solved.
    Could be coincidence. But I thought I’d pass it on.
    NOW, if someone could tell me why, when I have the power to my Sony M25 deck turned on, I sometimes get incessant dropped frames when playing a FCP sequence, I’d appreciate it. As soon as I turn off the deck the problem disappears. But that doesn’t seem right.
    Bob C
    (still running Tiger)
    MacPro 2 x 3GHz dualcore; 10 GB 667MHz
    Kona LHe
    Sony HDV Z1
    Sony HDV M25U
    HD-Connect MI
    Betacam UVW1800
    DVCPro AJ-D650
    Bob Cole replied 18 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
