Activity Forums Adobe Premiere Pro A positive report (so far)
  • A positive report (so far)
    Posted by Kevin Lawrence on July 20, 2012 at 7:49 pm
    This is a cross post. I put it in the Premiere Forum at Adobe. I post here as well, because when a company is doing something that works I want to encourage that. I’ve complained enough in the past, so…
    Additionally if there are other positive points this is an encouragement to post those, along with operational, technical and complaint posts 🙂
    ____________________________________________________________________
    I have been a long time Premiere user (version 3, yes 3, not CS3) onward and have been generally pleased with the overall experience. I also was being a bit of a bug about the subscription idea (too many bad experiences with the likes of Auto Desk and the ilk) and I found the idea of being forced to upgrade as versions came out or face an ever increasing upgrade fee distasteful. I have Master Collection and that is not inconsequential to do. Well after cooling my jets and actually looking at the Creative Cloud offer, I upgraded (at a very reasonable cost). Being on a continual upgrade path is nice as well.
    Positive Point One: Upgrade model is friendly
    Additionally since the version 6 Premiere I have dearly missed hearing audio in the trim monitor. When I complained I received overwhelming silence. Adobe suggested a feature request and the community said “maybe that was useful, I’ve never really needed that, what do you use that for”. My work flow. Timeline, fast forward looking for breaks and mark them, goto top and use shortcuts to advance to next marker, cut. Go to top, open Trim Monitor and advance through, quickly ripple and rock-n-roll through cut points (listening to audio as well as looking at picture to find the rough cuts)
    IT’S BACK!!! Audio in the trim mode . Additionally now material on different tracks trim just fine. No advancing along and skipping chunks on different tracks (I lift material to higher tracks for a quick sorting method. ie. Track 1 probably not useful, Track 2: potential use, Track 3 Primary Use)
    Also the new trim modes (which being a long time premiere editor, I am not that used to yet) appear to have great value.
    Positive Point Two: Trimming much improved
    So after complaining, I offer a Thank You to Adobe. And of course all the goodness all over the place, both Premiere and other apps make me giddy.
    Kevin L
    Derek Andonian replied 14 years, 1 month ago 6 Members · 12 Replies
  • 12 Replies
  • Nick Baer
    July 21, 2012 at 6:31 pm
    Have you figured out how to Paste Attributes, like in FCP?
    Getting a new menu with check boxes as to which attributes to paste?
  • Derek Andonian
    July 22, 2012 at 6:17 am
    You can do the same thing by highlighting a clip then go to the effect controls window and control-click the attributes you want, then copy them
    “THAT’S our fail-safe point. Up until here, we still have enough track to stop the locomotive before it plunges into the ravine… But after this windmill it’s the future or bust.”
  • Gus Evangelista
    July 22, 2012 at 4:25 pm
    The copying and pasting of attributes is the same principle but in different order.
    In FCP, you copy, paste attributes, select attributes.
    In PPro, you can select attributes, copy, paste.
    So, no, you can’t do it just like FCP.
  • Nick Baer
    July 22, 2012 at 6:59 pm
    THANKS!
    I am first and foremost using Premiere Pro because I can just drop my AVCHS files from my Panasonic TM900 and Sony A55 cameras, and not be bothered with pre-processing as in FCP 7 (haven’t tried FCP X yet – don’t want to corrupt any libraries that I made need to turn to with older FCP 7 projects).
    I am exporting 2 hour-long projects tonight, then I will pursue your tips in full.
    The big turning point is if I can work through the paste attributes correlation so I can build my motion menus the way I am used to in FCP 7.
    The other thing I am needing to work through is Encore. It is such a visual headache compared to DVDSP.
    the flowchart is so rigid in terms of being able to drag around to make something sensible. I posted in another thread https://forums.creativecow.net/thread/145/871392#871394 if you’d like to join.
    Thanks again,
  • Jim Watt
    July 23, 2012 at 1:57 pm
    I too would like to add that I’m very pleased with Premier Pro CA6. I switched from FCP7 early this year and of course there are adjustments, but I find it far more stable than FCP7. I’m editing 50 minute shows with mixed formats and just the time savings in PP’s ability to ingest a variety of formats without conversion is well worth the money.
    Are there a few issues? Sure, but they pale in comparison to the advantages.
    Thx…jw
    Producer/DP, HD series, “Discoveries…America”, “Discoveries…Ireland”, “Discoveries…Spain”,
    “Discoveries…Argentina”, Discoveries…India”, “Discoveries…Asia”, “Discoveries…Africa”
  • Nick Baer
    July 23, 2012 at 6:08 pm
    Do you author DVDs.
    I think my huge obstacle course will be Encore.
    How did you ever deal with the insanity of Encore, when DVDSP was/is so visually intuitive?
    One thing killing my progress with Encore is the empty menus/buttons library(s).
  • Kevin Lawrence
    July 23, 2012 at 6:44 pm
    I have been a long time user of Adobe products. Encore included. I have found Encore to be very straightforward. Having said that I have no experience with your preferred authoring package, maybe others can comment effectively?
    I am not sure why your library is “empty” Mine is populated with the content shipped as well as previous items I have authored.
    I find round tripping menus to Photoshop for build/edit to be seamless and also the asset tools work well for me.
    Kevin L
  • Nick Baer
    July 23, 2012 at 6:58 pm
    My DVD menus are usually 6 video clips as windows scaled down to about 20% each, with 20-seconds of moving video:
    * 2 rows of 3 across
    * 6 text boxes with 1-2 words naming the scene, under each video window
    – 1 text box for “play” and 1 text box for name of the DVD
    I make that in FCP, export as a 20-second .mov, then 3 of them as a 60-second .mov.
    Drop it into DVDSP as the background of a menu, draw the transparent “buttons” over the 6 video windows, plus “play”… Set the selected/activated colors and target for each button, start of track for “play”, and then each chapter for each button over video windows…
    The DVDSP flowchart is flexible, you can make several rows, and the arrows follow.
    So far, Encore is a stubborn mule when it comes to doing this GUI.
    My menu and button libraries are empty, came that way, on Adobe forums there others screaming that their’s were empty, too.
    I called twice to get my $49.99 Creative Cloud subscription. The first woman couldn’t help, transferred me to India. Two transfers there. They asked 100 questions about who I was. I hung up and got a guy in southern US, who set me up in 3 minutes.
    i fear I will need to call back. Glad Creative Cow is here for us, in Adobe’s delusional absence.
  • Tom Daigon
    July 23, 2012 at 7:04 pm
    Reading the PDF / Help manual always helps me work with software Im not familiar with 😉
    Tom Daigon
    PrP / After Effects Editor
    http://www.hdshotsandcuts.com
    https://www.youtube.com/watch?v=XRIg6h-LIm0
    HP Z820 Dual 2687
    64gigs ram
    Caligit HD Pro 2 16TB.
  • Nick Baer
    July 23, 2012 at 7:12 pm
    I like Apple software, where you don’t need a manual to use options/commands in the nav bar(s).
