Activity Forums Adobe After Effects A playing card with two images. Why the flicker!?
  • A playing card with two images. Why the flicker!?
    Posted by Charlie Hughes on January 4, 2008 at 9:29 pm
    Im making a playing card with two PSD layers. One for the face of the card, and one for the pattern on the back.
    I placed them in the comp, clicked 3D to both, parented one to the other, and raised one a single pixel from the other so that if i flip the card, i will not see the same pattern on both sides.
    However, when i rotate the card, one layer flickers with the other! Is this a glitch? I can’t think of why it would do this, so i can’t think of a solution.
    Any help would be very much appreciated. Maybe there is a better way of making one layer have a different reverse surface? There must be a way!
    Darby Edelen replied 18 years, 8 months ago 3 Members · 2 Replies
  • Steve Morris
    January 4, 2008 at 11:05 pm
    I get this same problem. The only way I seem to be able to get around it, is to separate the layers by more than one pixel. I have tried to use different advanced 3-D setting without much help. I have also noticed the problem does not show up when I am working in less than full resolution. The problem becomes visible when I set the comp to full res. I will be watching this thread to see what the answer is.
  • Darby Edelen
    January 5, 2008 at 2:37 am
    One solution is to make the side of the card facing away from the camera invisible, try this solution by Dan Ebberts:
    https://www.motionscript.com/design-guide/invisible-facing-away.html
    Darby Edelen
    Designer
    Left Coast Digital
    Santa Cruz, CA
