Activity Forums Adobe After Effects A perfectly looped and rotated background
  • A perfectly looped and rotated background
    Posted by Sergio García on June 12, 2022 at 8:29 am
    Hello!
    I’m doing a background which has a looped shape that I want to rotate. In order to achieve this I have used “rotate over time” and “CC Repetile”. The problem is that when it rotates, repetile adjusts the number of copies to fit them in the frame and it’s create a unwanted zoom effect.
    See it:
    https://www.youtube.com/watch?v=MetFsOgdTYE
    How can I achieve this repeated shape rotating without that unwatend zoom?
    Thank you all
    Filip Vandueren replied 4 years, 3 months ago 2 Members · 1 Reply
  • Filip Vandueren
    June 16, 2022 at 10:49 am
    You could precomp the rotating shape, or since you mention it is a shape, you could use shape repeaters instead of repetile which is a pixel effect.
