Activity Forums Adobe After Effects A partical tail following an object?
  • Joe Chao
    September 17, 2005 at 12:46 am
    have you tried this:
    creative a new solid layer,apply a Particle Playground effect to it,attach the position properity to the position of the ball by expressions.adjust the Particle system ,then you can get the effect.If you had a plugin “trapcode Particular “,you could get a “tail” from the presets. that plugin can make many beauticful partical tails.
