  • John Pale
    April 23, 2005 at 5:35 pm
    I think -31 should still be okay for you. As I understand it, -31, essentially leaves your audio level untouched from the original AIFF file, where the default -27 setting reduces your overall audio level. This is why you often have to jack up the audio on ‘Hollywood’ dvds to hear the dialog (though the effects then blow you out of your chair), which are mastered using this setting.
  • John Fishback
    April 23, 2005 at 5:50 pm
    I regularly push my audio to -6 so the track plays a bit hot. I use -31 in A.Pack and haven’t had a problem.
    Dual 2.5 G5 4 gigs RAM OS 10.3.8 QT6.5.2
    Cinema 23 Radeon 9800
    FCP4.5 DVDSP 3.0.2
    Huge U-320R 1TB Raid 3 firmware ENG12.BIN
    ATTO UL4D driver 3.20
    AJA IO driver 1.3.1 firmware v21-26
  • Eric Sampson
    April 23, 2005 at 6:39 pm
    Thanks guys for all your help!
