Activity Forums DaVinci Resolve A note on ATTO raid cards
  • A note on ATTO raid cards
    Posted by Blase Theodore on January 5, 2012 at 7:20 pm
    Just a heads up in case anyone else is inadvertently running into this…
    I’ve found that my ATTO R380 has a unique “feature” I only recently became aware of.
    When my system reboots, (11′ mac pro) the ATTO drops from an x8 device to an
    x1 device (and obviously speed drops to 1/8th).
    I went 8 months before I realized something was wrong.
    If I shutdown and fresh boot, its fine, only restarts cause the problem.
    I’d guess the problem is on the OS side as it tries to prioritize between all the x8 devices (red rocket, atto, decklink..)
    If you have an atto, you might want to just test that it working properly.
    Michael Cinquin replied 14 years, 8 months ago 2 Members · 1 Reply
  • Michael Cinquin
    January 11, 2012 at 4:06 pm
    My Areca Raid card used to do the same from time to time. I had even setup a startup-script to test for the raid speed and alert me if it was unexpectedly low.
    The problem went away when I changed computer, so I think it was a problem with a mac pro, not with the Card.
    BTW, I don’t recommend Areca Cards, driver for os x was troublesome for me, I had to deactivate a lot of options to make it reliable.
    Michael Cinquin
    Final Cut Pro – Avid Media Composer editor
    DaVinci – Color – Baselight colorist
    Color profiles for Color
    http://www.michaelcinquin.com/tools : tools for FCP | Color | RED | subtitles | Cinema Tools | Timecode – Keycode calculator
