Activity Forums Adobe After Effects A nifty way of drawing a mask, it’s automated
  • A nifty way of drawing a mask, it’s automated
    Posted by Tyler Paul on December 12, 2006 at 2:39 am
    If you’ve got a rather complex shape to mask you can use the Vegas plugin to draw it.
    Scale your object up so that it fits in a 1480 X 960 comp that’s 5 seconds long. (THE LARGER IMAGE MEANS A MORE ACCURATE RESULT)
    Throw the vegas plugin on it.
    Change the blend mode to transparent
    Set the number of segments to 1 and the length to 1000 and you’ll see your shape (MAKE SURE EVERYTHING LOOKS KOSHER)
    Keyframe the the vegas rotation to make one revolution
    Set the length to .0001 and you’ll see a dot that traces your shape
    If there are holes in your shape set vegas to render selected contours and do one contour at a time
    Pre-render, Vegas is a RAM hog
    Motion track the dot on the prerendered footage
    Apply the motion track to a null and copy the position keyframes
    Paste the keyframes onto a mask shape (YOU’LL NEED TO CLOSE THE MASK)
    It’s quick. Not to great for sharp corners but not terrible.
    “Life Should Come With Backround Music”
    -Brown Sugar Studios-
    Tyler Paul’s Toonificator V3.0Example Clip
    Kyle Hamrick replied 19 years, 9 months ago 4 Members · 3 Replies
  • Chris Smith
    December 12, 2006 at 4:52 am
    Very, very clever. Thx for sharing.
    Chris Smith
    https://www.sugarfilmproduction.com
  • Koolascucumber
    December 12, 2006 at 6:18 am
    woh
    gr8888 idea… kudos tyler..
    good work.. and
    thanx for sharing..
    aroonz
  • Kyle Hamrick
    December 14, 2006 at 2:52 am
    Sounds like sort of a lot of work to get something AE already does for you.
    Is this somehow superior to just using Layer>Auto-Trace? That’s totally automated, and you can do it for every frame in your work area, if you so desire.
    Or am I simply missing something here?
