Activity Forums Adobe After Effects A more realistic burn film
  • A more realistic burn film
    Posted by Malcolm Desoto on June 26, 2008 at 8:25 pm
    PLaying around with the Burn Film effect. I’m trying to think of some ways to make it look more realistic. So far I’ve duplicated the layer that I’m applying the effect to and setting it’s mode to multiply to get some darker colors as it burns. I’ve also done a little warping to the layer.
    I kinda want the dges around the burn spots to glow a little bit.
    I might even film some fire later and overlay it.
    “The secret to creativity is knowing how to hide your sources.” –Albert Einstein
    Chris Wright replied 18 years, 2 months ago 6 Members · 8 Replies
  • 8 Replies
  • Jason Milligan
    June 26, 2008 at 8:35 pm
    One of the things I like to do is put a pulsating lens flare on the layer beneath to mimic the light coming from the projector.
  • Malcolm Desoto
    June 26, 2008 at 8:43 pm
    hmmmm…that’s an idea.
    To be clear, this really isn’t film that I’m burning. This is spot for a steak house. So, lot’s of flames and such. I’m kinda using the film burn as a transition.
  • Mike Clasby
    June 27, 2008 at 6:52 am
    CC Glass can add a bit of melting bubbly effect.
  • Jens Enqvist
    June 27, 2008 at 7:25 am
    Roughen Edges with some bright edge color, to add a glow to the edges perhaps?
  • Malcolm Desoto
    June 27, 2008 at 4:38 pm
    Thanks. Both of those effects helped a little.
  • David Bogie
    June 27, 2008 at 6:44 pm
    One of the CC particle systems can use an alpha shape as the source for particles. You could, in theory, transfer the hot edges to a layer, precompose it, and apply the CC filter to it. You should be able to generate sparks, smoke or fire from the edges of the holes.
    Sorry,m not at my AE machine today. Grabbing from memory.
    In the olden days, back when AE was CoSA, we had fun shooting these as practical effects. At that time, we got questions about recreating the “Bonanza map.” Our solution was was to print the map, use some magician supply accelerant powders and liquids and light it off. Great fun.
    bogiesan
  • Malcolm Desoto
    June 29, 2008 at 1:01 am
    Great advice friend.
    hahahaha, love nothing more than creating those old school practical effects. I would still do it if these projects allowed the time.
  • Chris Wright
    June 29, 2008 at 3:27 am
    “da dunna dunna da dunna dunna da dunna dunnada da dunna dunna da dah”
    Bonanza tutorial!!!
    https://library.creativecow.net/articles/dallos_matt/fire.php
