Activity Forums Adobe After Effects A mask on trapcode particular ?
  • A mask on trapcode particular ?
    Posted by Fred Benac on December 14, 2006 at 6:52 pm
    Hi everybody,
    I don’t think that something is impossible with trapcode plugins and After effects…
    But i can’t have a mask, on particular for example.
    The only solution that I found is to use a mask on a background copy over the layer with particular.
    But the problem’s that we can’t kept transparency.
    Is there a solution for this matter?
    -stev=o replied 19 years, 8 months ago 4 Members · 4 Replies
  • Julian Sixx
    December 14, 2006 at 7:00 pm
    Hi
    [Mandie] “Is there a solution for this matter?”
    precompose your Particular layer
  • Fred Benac
    December 14, 2006 at 7:09 pm
    Are you sure??
    I even do this, and i remember that wasn’t possible…but may be i’m wrong
  • Andrew Kramer
    December 14, 2006 at 7:28 pm
    Have you tried using the Track Matte Function? Just put your mask on a layer above the particular and add your mask to it and set the track matte for the particular layer.
    Good Luck,
    Andrew Kramer
  • -stev=o Create COW Profile Image
    -stev=o
    December 14, 2006 at 7:31 pm
    When you precompose your layer, make sure that you’re “moving all attributes” to the new comp.
    -stev=o
