Activity Forums Adobe After Effects Expressions A little math help…
  • A little math help…
    Posted by Stephen Reber on September 25, 2009 at 2:41 am
    Hey guys…
    I’m a little stumped here. I am using Math.sin() and want the sine to go from 0 to 1 rather than -1 to 1.
    What I am confused about is that, from what I understand, by the order of operations, both expressions should put out the same result. From what I remember, everything in the parenthesis go first then everything on the outside goes next * / + – in that order. But I get two different results, the first expression gives a result of 0 to 400 and the second expression gives a result of 0 to 1.
    Thanks in advance…
    Stephen =]
    First expression, bad result...
    x = transform.position[0];
    y = 2 / (1+ Math.sin(time * 2 * Math.PI));
    [x, y]
    Second expression, good result
    y = (1+ Math.sin(time * 2 * Math.PI)) / 2;
    [x, y]
    Stephen Reber replied 16 years, 11 months ago 2 Members · 2 Replies
  • Dan Ebberts
    September 25, 2009 at 1:57 pm
    You’re right about the parentheses, but in your first expression you end up with 2 divided by the stuff in parentheses and in the second, it’s the other way around. The order of the operands doesn’t matter for multiplication, but it does for division.
    Dan
  • Stephen Reber
    October 3, 2009 at 4:17 am
    EXCELLENT!
    Thanks Dan =]
