Activity Forums Compression Techniques A little guidance regarding scale down resolutions
  • A little guidance regarding scale down resolutions
    Posted by Daniel5000 on March 26, 2008 at 2:48 pm
    Hello
    Just curious if what I’m doing is a good general workflow or…are there alternatives?
    When I encode standard definition clips for computer playback, web or CDROM, I usually do a proportional scale down, depending on the job specifications. For example: Master video is PAL 720 x 576 with a proportional scale down to the following resolutions:
    75% of source 540 x 432
    50% of source 360 x 288
    25% of source 180 x 144
    I guess it’s the same workflow for HD clips. So
    1280 x 720
    75% of source 960 x 540
    50% of source 640 x 360
    25% of source 320 x 180
    I guess I can also calculate based off aspect ratio –
    Multiply the desired height or width by 1.778 or .5625 (for 16:9 material)
    What’s the question???
    Hmmm…Does the above sound logical? Can I be doing something wrong?
    Daniel
    Daniel Low replied 18 years, 6 months ago 2 Members · 1 Reply
  • Daniel Low
    March 26, 2008 at 2:59 pm
    Your standard def aspect ratios are wrong. Remember that 720×576 is 4:3 (1.333) using non-square pixels. Web CDROM etc all use square pixels.
    Although the following link relates to flash video, the frame size tables are relevant for all square pixel delivery formats:
    https://blog.influxis.com/influxis/?p=14
    Please post back saying what solved your problem. It could help others, and saying ‘thanks’ is free!
