Activity Forums Adobe Creative Cloud A hard question about GTX GPU
  • A hard question about GTX GPU
    Posted by Shany Levi on January 6, 2015 at 2:13 pm
    ok, first of all I want to apologize for my grammar and for the chance I’m writing this post in the wrong place (couldn’t find an answer in other places).
    Here is the thing:
    I’m going to buy a strong laptop for graphic designing and video editing (illustrator, Photoshop, indesign, premiere, After effects, audition etc..). I’ve started a research a week ago about GPUs and I’m having trouble with understanding few things:
    I know there is no much point in comparing two GPU with spec’s only. I know that numbers don’t mean anything and the most reliable test is giving both of the GPUs the same action and and then comparing the results.
    But as I said, I mostly use Adobe’s softwares (different calculation than games fps count)- and I can’t find this kind of tests for the GTX 970M/980M. Fix me if I’m wrong, but:
    1. Isn’t the 970M is a completely different GPU than the 970 (non mobile)?
    2. Where can I find relevant tests for my needs from those GPUs?
    3. What qualities should I look for when I look for a good GPU for my needs (As mentioned)?
    Another thing is when I look on “notebookcheck.net” for example, they don’t even mention the “VRAM”.
    https://www.notebookcheck.net/NVIDIA-GeForce-GTX-970M.126694.0.html
    They only say “for the up to 6 GB of GDDR5 memory” for example.
    4. What does it mean “up to”? DOES IT MEAN THAT THERE ARE ALWAYS TWO VERSIONS OF THE SAME GPU MODEL? A one with 3gb and a one with 6gb?
    5. And my most important question:
    I can’t understand if Adobe’s softwares know how to use SLI.
    6. If SLI is not supported – would it be right to say that I better buy a laptop with one GTX 980M than a laptop with SLI GTX 970M (given the fact that a single 980M beats a single 970M)?
    7. Is a not-supported SLI GTX work like the single version of this GTX?
    Thank you so much for your patience!
    You’re the best!
    Shany.
    Shany Levi replied 11 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
