Activity Forums Adobe After Effects a glitch every few frames
  • a glitch every few frames
    Posted by Roy Messinger on February 17, 2009 at 5:18 pm
    Hi all,
    I installed CS4 master collection recently (I have Vista 64bits, 4GB, Q9450) and my problem is as followed:
    I make a composition in AE and import it to PPRO. Whenever I render the timeline in PPRO (the composition is like other ‘items’ in the timeline (using
    dynamic link), I see once every few frames a ‘glitch’ or some kind of interrupt in the movie. this goes only one frame, and in random places on the
    frame. I tried to switch between ‘optimize for performance’ and ‘optimize for memory’ in the preferences of PPRO, but there’s no different.
    Very weird, I must say.
    Does anyone have an idea?
    My only option is to export the compostion in AE to an AVI and then import it as a regular file to PPRO, but I lose all the benefits of dynamic link, bad idea…
    (how do I attach a file here? I wanted to show you a freezed frame with such glitch)
    Roy
    Roy Messinger replied 17 years, 6 months ago 2 Members · 2 Replies
  • Brendan Coots
    February 17, 2009 at 5:33 pm
    More often than not, intermittent glitch frames within AE mean corrupted buffered frames. Simply purging the RAM cache within AE will almost always clear these issues up.
    That said, I don’t really use dynamic link so I’m not sure if this fix would apply in your situation, but it’s worth a shot. Not in front of AE right now but I believe you can find it under Edit>Purge>Purge All.
    Brendan Coots
    Splitvision Digital
    http://www.splitvisiondigital.com
  • Roy Messinger
    February 17, 2009 at 5:57 pm
    Wow!
    It helped!
    Thanks alot!!!
    What the ‘Purge All’ means?
    Roy
