Activity › Forums › Adobe After Effects › A frequency analyzer for After Effects CS4 audio(Trapcode Form)?…
  • A frequency analyzer for After Effects CS4 audio(Trapcode Form)?…
    Posted by Aza Allen on February 20, 2010 at 1:31 am
    Ok, So I have the Adobe Master Collection…
    I am trying to use the Audio React inside Trapcode Form for After Effects CS4…
    The only thing is, I’m not sure which frequencies I want it to respond to in my Audio track, what is the best (or easiest) way to view the frequencies in my audio (even if I have to go outside AE to do so) so I can determine which would be the best to use?
    Thanks all,
    Aza
    Make sure to check out my Heroes Fan Film at https://ruesterprod.blip.tv
    Walter Soyka replied 16 years, 7 months ago 3 Members · 3 Replies
  • Scott Roberts
    February 20, 2010 at 5:13 am
    Viewing playback via a graphic equalizer should give you a visual breakdown of the various frequencies. Is this what you mean?
    https://www.youtube.com/graphicsdump
    https://www.myr3d.com
  • Aza Allen
    February 20, 2010 at 7:00 pm
    Well, a graphic equalizer allows you to adjust specific frequencies, but which ones will also show the frequencies are being used in a particular song graphically ie- so I can watch the song being played and go, oh, the chorus (instrumental)seems to be using these particular frequencies, so I can set Form to react to frequencies in this range, etc.
  • Walter Soyka
    February 20, 2010 at 10:45 pm
    AE has a built-in effect called “Audio Spectrum” that might be helpful to you.
    Walter Soyka
