Activity Forums Adobe After Effects A frame in an image sequence
  • A frame in an image sequence
    Posted by Esky Ching on December 2, 2011 at 4:11 am
    Hello!
    I have imported a time-lapse image sequence (a few thousand JPEG images) into AE’s composition, during the preview I got an “unexpected end-of-file” error somewhere in the middle of the composition.
    Usually, it is caused by the corrupted image.
    I can’t find which image in the sequence causes the problem.
    Although I can do a calculation base on the time line, it takes a bit of effort to do so.
    Is there any smarter way to find it?
    Thanks.
    Esky Ching replied 14 years, 8 months ago 3 Members · 4 Replies
  • Angelo Lorenzo
    December 2, 2011 at 5:30 am
    Ctrl+click (Windows) the timecode display on your timeline panel. This will switch it from timecode to absolute frames. Corrupt frame is usually +/- a frame or two from where it crashes.
  • Esky Ching
    December 2, 2011 at 6:41 am
    Thank you for your reply.
    This is the way I am doing.
    The thing is, my sequence is not starting from 0
    a little bit of calculation is needed (although I have done that already).
    If there is something like, when I stop at certain frame (or 1 frame before/after) of an image sequence, I can right-click and choose “Reveal this frame in Finder” will be perfect.
    Maybe I should write to Adobe putting it as a request feature for image sequence.
  • Walter Soyka
    December 2, 2011 at 6:53 am
    [Esky Ching] “The thing is, my sequence is not starting from 0 🙂 a little bit of calculation is needed (although I have done that already).”
    You can change your composition’s starting frame in composition settings [link]. It won’t affect rendering at all, but you could use this to make your comp frame counter match your image sequence frame counter.
    Walter Soyka
  • Esky Ching
    December 2, 2011 at 7:12 am
    Wow!
    This is the feature I’ve been ignoring.
    Thanks very much!!!
