Activity Forums Maxon Cinema 4D A flickering light effect on polygons/ tracers ?
  • Brian Jones
    October 11, 2018 at 3:04 am
    keyframing the value necessary (for the lights as they flicker on it could be Intensity if they are regular lights with volume visibility or Luminance Brightness/Color in a luminant material on objects). For the poly faces it’s the same sort of thing keyframe the alpha or transparency
  • Rajarshi Basu
    October 12, 2018 at 5:36 am
    Thanks for the reply. Do you think it can be done procedurally with shaders ?
    Like the video link reference, the effects is very minimal and looks classy.
  • Brian Jones
    October 12, 2018 at 3:19 pm
    looks like 3 – 5 pulses as the lights or polys flicker or come on. That’s very easy to keyframe but if you wanted to do it with a shader, I can’t think of a way right now but assuming it’s possible you’d likely have to keyframe the start/stop though that would be less keyframing… GSG’s Signal might be a way (not free though) and you could use a noise node in xpresso to flicker lights or luminance/alpha/transparency (PixelLab has a short Tute on this). Lester Banks has a tute where the Vibrate tag is used, with xpresso again…
