Activity › Forums › Apple OS X › A few Raid questions
  • A few Raid questions
    Posted by Glenn Grant on August 25, 2009 at 4:46 pm
    I have two questions about a Raid set ups.
    I have a Sonnet five disk raid 5 set up attached via eSata with a G-tech raid controller card. I have one large project on it, that I only work on from time to time. I might work on it a few days in a row, and then not get back to it for a week or two.
    My question is should I turn off the enclosure at night and turn it back on every morning, or just let it run all the time? What if I know I won’t need it for a week or so?
    I also backed up all the media onto two internal hard drives stripped together using the disk utility raid. Can I safely remove these two drives and reinstall them later if needed, or will that mess me up?
    Glenn
    Hey, I just figured out how to get ride of my Legacy Name!
    Glenn Grant replied 17 years, 1 month ago 2 Members · 2 Replies
  • Curtis Thompson
    August 25, 2009 at 4:50 pm
    hello…
    2nd one is hard to answer w/o more info, but you’ll always extend the life of a hard drive if you turn it off, plus you’ll save power, so ya – if you don’t need it for a week at a time, it can’t hurt to properly shut it down and then turn it back on. i wouldn’t do it 10 times a day, but for extended periods of down time, sure…
    sitruc
  • Glenn Grant
    August 25, 2009 at 11:29 pm
    Thanks Curtis, I thought it would help save energy if I could turn it off. What about at the end of the day if I know I am going to use it the next day should I leave it on?
    I will just leave the internal drives alone. I was hoping to take them out so I could add a new drive for a clean instal of the OS and FCS 3. But I can remove one of the other drives for that.
    Glenn
