Activity › Forums › Adobe Premiere Pro › A few questions…
  • A few questions…
    Posted by Eric Santiago on January 31, 2016 at 9:26 pm
    I am posting a few questions to see if anyone can jump in and help answer them.
    Some will be basic others will be wishes.
    I want to start with a simple one.
    I have numerous bins in a project.
    When I do a search, why does Premiere have to show all the folders that are not involved with the file Im looking for?
    I find this cumbersome most of the time.
    A tougher on, is there a better way of collapsing video during clean-up.
    I started cutting and moving video tracks into a single one and would like a much quicker option.
    Blade then move is way too tedious. Mind you this is an inherited project so I know that I would have never subjected anyone to this kind of set-up.
    Also is there a way to merge clips that have been cut within a track?
    This is quite the pain when going back into XML for other workflows one being import XML into REDCINE and notice that one clip has to instances.
    I will be adding more and if anyone wants to add their own question go for it.
    Eric Santiago replied 10 years, 7 months ago 2 Members · 4 Replies
  • Eric Santiago
    February 2, 2016 at 12:48 pm
    After a few days into this project I am finding that Premiere needs to adopt some helpful functions from other apps.
    Besides the merge clip into lower track a “open in timeline” option would really help when doing quick and dirty audio tricks.
    I know I could use nesting but that takes a bit more steps and it doesn’t transfer well to other apps during XML export.
  • Eric Santiago
    February 9, 2016 at 3:40 pm
    Adding to my list.
    Is there a way to remove all transforms with one click in Premiere.
    Received a project with over 1500 edits and I’m not about to sit through each clip too see what was transformed.
  • Tero Ahlfors
    February 9, 2016 at 4:19 pm
    Select all – right click – remove effects
  • Eric Santiago
    February 9, 2016 at 4:43 pm
    Thanks Tero why I didnt think of that 🙂
