Activity Forums Adobe Premiere Pro A few new MacPro fall 2019 questions
  • A few new MacPro fall 2019 questions
    Posted by Steve Zavo on September 9, 2019 at 6:56 pm
    Can anyone answer these please regarding MacPro fall 2019:
    Maybe I want to stick with my beautiful NEC monitors.
    Will those connectors remain the same? (DVI-D)
    Will there be a way to connect my eSATA drives?
    Can anyone suggest a most appropriate configuration
    from this page, eg processor, memory:
    https://www.apple.com/mac-pro/specs/
    for Photoshop files, some times up to 1.5 GB;
    video editing: generally 60 4K 2 minute clips at a time input;
    2 minute finished videos 4K output.
    Steve Z
    Todd Perchert replied 6 years, 11 months ago 3 Members · 2 Replies
  • Shane Ross
    September 10, 2019 at 12:50 am
    [steve Zavo] “Maybe I want to stick with my beautiful NEC monitors.
    Will those connectors remain the same? (DVI-D)”
    You’ll need thunderbolt adapters.
    [steve Zavo] “Will there be a way to connect my eSATA drives?”
    You’ll need an adapter, most likely USB-C will be the option.
    [steve Zavo] “Can anyone suggest a most appropriate configuration
    from this page, eg processor, memory:”
    You can afford more than the base model? I can’t even afford that. The base would be fine for many many things, even Resolve and PPro. Get what you can afford.
    [steve Zavo] “video editing: generally 60 4K 2 minute clips at a time input;”
    You’ll need drives with connectors far faster than eSATA. Thunderbolt 3 RAIDs for 4K 60p. Fast drives is what helps with large data rate video filse.
    [steve Zavo] “for Photoshop files, some times up to 1.5 GB;”
    64GB RAM
    [steve Zavo] “2 minute finished videos 4K output.”
    This can be done quickly with an iMac 5K, nothing special about that. 2 min? Lickity split…base MacPro will do that.
    Shane
    Little Frog Post
  • Todd Perchert
    September 10, 2019 at 2:00 pm
    I would just go with the 1.5TB RAM. Excess is what’s needed here. LOL!
    I just wonder what they charge for 1.5TB of RAM loaded into it…
