Activity Forums Apple Final Cut Pro a few issues after the update(s)
  • a few issues after the update(s)
    Posted by Bret Williams on April 16, 2015 at 6:18 pm
    Since the update to X and OS X 10.10.3 (from 10.10.2) I’ve had some odd issues. X keeps hanging on restoring the window layout. I’ve never had to trash my window layouts before and now I’m doing it daily.
    Sometimes on a reboot I lose connection to my TB drive and the 2nd monitor that is looped through the drive. The drive fully turns itself off on the reboot. (pegasus raid). Turning it on connects it and restores the monitor.
    Also, most annoyingly, I’ve started to have to force unrender sections of the timeline that don’t seem to recognize layers have changed. This just like the old FCP 7 days. But unlike legacy, forcing it to unrender isn’t as easy. In legacy I’d change something and then change it back. Legacy was so dumb that it didn’t realize it still had a cached render matching that need. But X is too smart for that. When you change the parameter back, it links right back up with the (incorrect) render file.
    Mark Suszko replied 11 years, 5 months ago 4 Members · 5 Replies
  • Tim Jones
    April 16, 2015 at 6:33 pm
    [Bret Williams] “Sometimes on a reboot I lose connection to my TB drive and the 2nd monitor that is looped through the drive. The drive fully turns itself off on the reboot. (pegasus raid). Turning it on connects it and restores the monitor.
    Try a different Thunderbolt cable. We’ve discover 4 of our original cables were not “full strength” any more and were witnessing similar TB device drops. Replacing he TB cables has solved that here.
    Tim
    Tim Jones
    CTO – TOLIS Group, Inc.
    https://www.tolisgroup.com
    BRU … because it’s the RESTORE that matters!
  • Bret Williams
    April 16, 2015 at 7:30 pm
    Started literally with the first reboot after the update to 10.10.3. I don’t think it’s the apple tb cable.
    Now I’ve got another new one. If I monitor through my BMD device, mono sources in the event can’t be heard until they’re tagged stereo. But you do see the meter moving. If I switch monitoring back to the computer, it’s fine. That started a couple hours ago with the BMD driver update! Lovely.
  • Jeremy Garchow
    April 16, 2015 at 7:50 pm
    This has not been a great release.
    There’s a supplemental 10.10.3 update that came out today, don’t know if that will help you.
  • Bret Williams
    April 16, 2015 at 9:55 pm
    Oh I shall try that and report back on everything is screws up.
  • Mark Suszko
    April 16, 2015 at 10:01 pm
    I had your same Pegasus problem BEFORE the OS and FCPX upgrade.
