Activity › Forums › Adobe After Effects Expressions › A few fairly simple questions
  • A few fairly simple questions
    Posted by Jonathan Cutrell on June 9, 2010 at 4:13 pm
    Alright, so here’s what I am trying to do.
    I would like to set the position of a mask path as well as the anchor point of each layer based on its index; Essentially I am wanting to mask blocks of a composition/footage 10-20 times.
    After this, I will be using a combination of mosaic and linear wipe to fade rectangles from white to black – anyway, what I need is a point sample of the alpha or white value (I suppose this would be brightness). How would I sample a point’s color value? Each of these layers will be animated according to the black-white level.
    Todd Kopriva replied 16 years, 3 months ago 2 Members · 1 Reply
  • Todd Kopriva
    June 9, 2010 at 11:38 pm
    You can use the sampleImage method to sample colors. Here’s a blog post that shows an example:
    https://blogs.adobe.com/toddkopriva/2009/07/color-sampler-using-sampleimag.html
    There are also some great examples on Dan Ebberts’s website and a few others linked to from the bottom of the Help page about sampleImage.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
